3point lift???
Craig
08-16-2002 08:59:11
I just got my loader hooked up with new hoses.IM not sure why the 3-point lift wont go up?Any thoughts>>>
TomG
08-17-2002 04:10:03
 Re: 3point lift??? in reply to Craig, 08-16-2002 08:59:11
If the loader valve assembly is a power beyond type, reversing the PB and the Tank return lines would produce the problem in the most common type hook ups.
Craig
08-19-2002 19:33:36
 Re: Re: 3point lift??? in reply to TomG, 08-17-2002 04:10:03
Ive bleed the pump, and am getting fluid.What do you mean by reversing the lines?My tractor has the valves located under the seat , bolted to the top of the tranny.What lines should I change?The loader seams to go up a little slow , could it be the pump? Thanks , Craig..
Polish Mike
08-16-2002 10:48:44
Are you sure the hydraulic pump isn't airbound ? You may have to bleed it.
