3-point moves by it self
joe ross
08-18-2002 09:15:07
i have a naa and my 3 point while mowing or doing anything it slowly drops about two inches and then jerks up to the prior set level. this is about a one minute cycle. i have tried moving the draft control on the right side but if you try and move it to the horizontal position it just raises the mower all the way up and keps it up until you return the control to the vertical position. thanks joe
Phil (VA)
08-19-2002 13:38:50
 Re: 3-point moves by it self in reply to joe ross, 08-18-2002 09:15:07
I would check the control valve. I don't have my manual handy, but I think that's the one on the front of the lift cover, the one you can get to without removing the cover. It has a detent ball and spring. It may be gunked up or the ball may be out of position, etc.
Fred
08-18-2002 18:15:27
Gerry was lucky. Normally the problem is a leaking piston due to a bad o ring, worn piston and/or cylinder. It could also be a leaking control valve. A quick and dirty temp fix while you mow is to use a pair of limiter chains. They keep a perfect height and take all of load off of the hydraulics. Fred
Gerry
08-18-2002 13:53:11
Joe: What you discribed sounds like the "hiccups or bobbing". My NAA did this and one cause is leakage by the piston cylinder. They say it will get worse as the oil warms up. The I&T manual goes into this condition on page 34 or paragraph 115C. The test for this is to warm the oil, put a heavy implement on the lift and pop the oil filler and look to see if it is leaking out around the cylinder. I did nothing to mine other than change the oil and it went away. Good luck...
