Order Ford 600 Parts Online
Ford 3600 clutch question
Bob - ECen KS
08-19-2002 07:56:05
I just added a 1977 ford 3600 gas 6/2 to my small 'stable' of now 3 tractors. The person I bought it from swears he had a new clutch put in just before selling it but the clutch doesn't work properly (to me). I have to depress it all the way to change gears, and the pto starts at the same time as the 'motion'. I've checked the adjustment on the external linkage and I can feel the throwout bearing 'hitting' the clutch fingers (or something) with about 1/8 inch movement on the extrenal clutch arm. When I've seen this problem before the 2 stage clutch was all out of adjustment. From reading on here it seems I have to remove the steering gear box to get to the adjustment hole for the 2 stage clutch, then use a 1/16th drill bit to set it. Am I understanding what I've read correctly here and does this seem like a 2 stage clutch adjustment problem to those of you who have seen a 3600 before? This seems like a lot of grief to adjust a clutch but I sure don't see any access holes other than an inspection plate on the front of the bellhousing and I assume the adjustments have to be on the other side of the flywheel. Am I going to hate myself for taking this apart?? ;). Any advise or info would be appreciated.
thanks in advance,
Bob
Don
08-20-2002 06:09:36
 Re: ford 3600 clutch question in reply to Bob - ECen KS, 08-19-2002 07:56:05
My '75 3600 has a 2 stage clutch. Let up a little, PTO engages, let up the rest, transmission engages.
RickB.
08-19-2002 14:42:20
You may want to verify by the transmission code whether your tractor has live PTO and a 2 stage clutch. If it is a 6F/2R transmission and not an 8F/2R, you could well have transmission-driven PTO. Your description of its operation matches that. Usually a 2 stage clutch that needs an internal adjustment will not unload the PTO disc at all, making the PTO shifter grind as it is shifted in.
thanks for the tip
08-19-2002 18:41:27
 Re: Re: ford 3600 clutch question in reply to RickB., 08-19-2002 14:42:20
next to last number on the product code is 2, which if I read correctly is a 'transmission' pto ;( - I didn't know ford made those after the 8N. At least you got me straightened out before I tore into it and ended up even more embarassed - thanks again for the help.
Bob - ECen KS.
