Order Ford NAA Parts Online
1953 Ford Jubilee
Mark Brown
08-21-2002 19:47:06
This is my first time at post a message. I have just recently purchaced my Jubilee and the PTO hydraulics are'nt working right, when I put a bushhog on it will not lift it up. It attempts to by lifting 4-5 inches but will not lift the back wheel off the ground does the pump that is mounted on the right side of the engine need to be rebuilt. What do I need to look for when I tear it down Thanks
Phil (VA)
08-22-2002 08:29:23
 Re: 1953 Ford Jubilee in reply to Mark Brown, 08-21-2002 19:47:06
Mark, it could be lots of things. It could be the cam follower pin, which often wears. You will have to remove the top cover (under the seat) to replace that. Look in the archives for all the possibilities. Zane probably can give you some good advice, so one tip might be to search for his name.
Mark B
08-22-2002 21:54:05
 Re: Re: 1953 Ford Jubilee in reply to Phil (VA), 08-22-2002 08:29:23
Where do I find archives at. Do you think I can rule out the hydr. pump mounted on the right side of the engine
Cliff (VA)
08-23-2002 03:34:18
 Re: Re: Re: 1953 Ford Jubilee in reply to Mark B, 08-22-2002 21:54:05
No, I would not rule out the pump completely. But, it is much easier to work on the other end and there are more suspects there. You can even look into the hydralic fill port or partially drain the hydralic fluid and remove the side inspection ports and see if there is a leak (such as at the pressure relief valve).
To get to the Archives try "Search This Site" under "Research & Info" on the left edge of this window.
