Engine runs on.
Al
08-21-2002 20:00:33
On my 62' 4000 172 cid.gas.After turning off the iginition switch the engine runs on for a few revolutions,like it's dieseling.Any sugesstions?
MarkB
08-22-2002 15:27:45
 Re: Engine runs on. in reply to Al, 08-21-2002 20:00:33
A likely cause is carbon buildup inside the combustion chambers, which can get hot and ignite the mixture after the switch is off. Try a can of one of the various fuel additives that claim to clean combustion chamber deposits.
Also, make sure that you engine idles down properly. If the idle is too fast, it won't want to shut off.
Always let your engine idle down for at least five or ten seconds before you shut it off. That gives the combustion chamber a chance to cool off.
Phil (VA)
08-22-2002 10:34:58
Too much octane in the fuel will sometimes cause dieseling too. Did you by chance put a tank of 93 or 94 octane in the tractor?
Please explain to me..............TimK
08-23-2002 07:08:16
 Re: Re: Engine runs on. in reply to Phil (VA), 08-22-2002 10:34:58
Respectfully, I don't understand your response, since octane is simply a measure of anti-knock ability of the fuel. In fact, it seems to me that the lower gasoline octane would have a better chance of dieseling than the slower burning, anti-knocking of the higher octane. But, I'm here to learn..... ..... .
phil (va)
08-26-2002 06:15:38
 Re: Re: Re: Engine runs on. in reply to Please explain to me..............TimK, 08-23-2002 07:08:16
You're right. I stated it backwards. However, the point is still valid. Since he found the problem, it doesn't apply to him, but the wrong octane gas can cause run-on or dieseling.
DavidO...Agree
08-23-2002 11:12:03
I agree. Maybe you are doing a little teaching too.
This great Board operates on Socratic discussions...............TimK
08-23-2002 13:12:52
 Re: Re: Re: Re: Engine runs on. in reply to DavidO...Agree, 08-23-2002 11:12:03
Smitty
08-21-2002 20:17:23
you might want to check your timing, too far advanced will cause an engine to diesel and also run a little hotter
TimK
08-22-2002 06:22:46
 Re: Re: Engine runs on. in reply to Smitty, 08-21-2002 20:17:23
Timing is off, engine is running hot, idle is set too high, wrong plugs which cause carbon build-up which causes compression to increase which causes dieseling. If you have just done a rebuild, could be a metal head gasket hanging over a little into the combustion chamber heating up and pre-igniting the fuel. MY $.02
Al
08-23-2002 20:00:08
 Re: Re: Re: Engine runs on. in reply to TimK, 08-22-2002 06:22:46
The timing is good,but the idle was set too high.Reset idle and all is good.
