641 Leaking Fuel Shutoff Valve
Bill D (Va)
08-22-2002 06:01:51
I have read on this board about valve replacement and O-ring replacement. Considering the $40.00 difference between the two fixes, what would be recommended? Do the replacement O-rings last as long as a new valve assembly, etc?
Thanks
Dan
08-22-2002 17:12:07
 Re: 641 Leaking Fuel Shutoff Valve in reply to Bill D (Va), 08-22-2002 06:01:51
Bill, the o ring seals the valve to the tank. If thats where the problem is an o ring will fix it. You may also have a leak in the valve. Gas will leak by the shut off screw. Replacing both is a pretty sure bet.
rasputen
08-24-2002 07:41:54
 Re: Re: 641 Leaking Fuel Shutoff Valve in reply to Dan, 08-22-2002 17:12:07
Dan, he is refering to dismanteling the valve and installing a new oring on the stem.
bd
DonP
08-22-2002 07:34:58
I had a leaky shutoff, I bought a new one for about $42.50, and still had a leaky shutoff after installing the new one.
-but it did give me a "spare" so I could use the tractor while I put an o-ring in the old shutoff.
It's only been a year or two, but the o-ring is holding, the shutoff isn't leaking.
