Order Ford 3000 Parts Online
3000 SOS NO PRESSURE
John
08-25-2002 20:33:36
I'm trying to get this 3000 to move,pto rotates and with the top cover off I can see the main drum rotating.I did the pressure checks and screen check. The filter seems alittle loose. I removed the valve body and there is no movement of fluid from the main pump.This tractor has been setting for a long while and the front seal was popped out.Do you ever have to prime the pump?
Larry NCKS
08-26-2002 04:22:24
 Re: 3000 SOS NO PRESSURE in reply to John, 08-25-2002 20:33:36
Never in my experience have i had to prime this pump. You must have a bad pump or pump drive splines stripped on pump or shaft.
John
08-26-2002 20:16:10
 Re: Re: 3000 SOS NO PRESSURE in reply to Larry NCKS, 08-26-2002 04:22:24
Thanks Larry, the pump was broken apart,spline looks good, so I'm gonna try a new pump to see if she moves for me for the first time!
