Order Ford 3000 Parts Online
3000 ignition problem
Clayt in Ohio
08-29-2002 07:20:34
The 3000 gas will work for about an, then shuts off. The resistance gets smoking hot. I installed a new resistance wire and the same thing happened.
Maybe someone else has hadthis problem and can give me some much needed advice.
Thanks in advance, Clayt.
Bill
08-29-2002 11:55:57
 Re: 3000 ignition problem in reply to Clayt in Ohio, 08-29-2002 07:20:34
replace the coil.. be sure to use a coil made for an external resistor and for the right voltage..ie 12 volt coil on a 12 volt system..
