Order Ford 860 Parts Online
Ford 860 Sputtering.
ArBe
08-29-2002 07:54:53
My 55 Ford 860 runs fairly well but not smooth. It doesn't matter if it is under load or idling. What would be some of the issues just from my short description as to check to get her going smooth. (I have new plugs and points in it but didn't change anything).
D. R . White MN
08-29-2002 14:43:58
 Re: Ford 860 Sputtering. in reply to ArBe, 08-29-2002 07:54:53
Check the sparkplug wires first if their OK do a compression check. Chould be a burnt valve. Hope this helps. Dave.
Jim.UT
08-29-2002 09:38:42
Run it at night in the dark. Look at the spark plug wires. Do you see little sparks all over? If so, replace the wires with copper wires.
