Order Ford 600 Parts Online
3600 PTO CLUTCH WILL NOT RELEASE
BOB
08-31-2002 17:04:06
I ADJUSTED THE CLUTCH TO NO FREEPLAY, NO GOOD ANY HELP OUT THERE THANKS BOB
Bill
09-01-2002 06:34:53
 Re: 3600 PTO CLUTCH WILL NOT RELEASE in reply to BOB , 08-31-2002 17:04:06
check to see if the clutch rod is in the right hole where it attaches to the clutch arm.. if there are two holes on the clutch arm, the rod MUST be in the hole that raises the pedal higher.. this will enable the pto clutch to be disengaged.. the other position is for work without the pto and allows a much more comfortable pedal postion.
