Order Ford 4610 Parts Online
4610 adjusting hydraulic speed
Tim N KY
09-03-2002 08:15:54
My F-S adjustment valve on the side beneath the seat will not turn in either direction. If it's stuck what must I do?
Bill
09-03-2002 10:32:50
 Re: 4610 adjusting hydraulic speed in reply to Tim N KY, 09-03-2002 08:15:54
keep spraying it with wd40.. and taking a pair of channel lock type pliers and trying to turn both directions just short of breaking the plastic knob.. DO NOT BREAK the plastic knob!!!!!it may take a week of spraying and working the knob..
win you break it loose finally.. you will find out that you rarely, if every use it.... unless you "draft" plow alot, then the speed of the draft can be slightly slowed down if necessary...for light soils...like sand and such..
