Order Ford NAA Parts Online
Jubilee Loader mounting
ADK Dude
09-03-2002 09:47:01
Hi I have a 53 NAA and a Wagner WM3 loader. I dont have the front bracket to mount the loader, does anyone either have a bracket or a picture so I can try to make one. I've looked everywhere, would the bracket be the same for 600 and 800 series Fords.
My tractor has a later piston type hydraulic pump, its blue, maybe off a 2000 or something, would such a pump be able to drive the loader or would it be too slow?
Thanks in advance for any help.
Phil (VA)
09-04-2002 10:07:57
 Re: Jubilee Loader mounting in reply to ADK Dude, 09-03-2002 09:47:01
The front bracket is real simple. I don't have a drawing or measurements, but there isn't much to it except a trapezoidal piece of steel, probably 3/8 in. thick with five or six holes in it, as I recall. It does have a slight bulge at middle-top. Now, having said that, I have a WM3 loader on a Ferguson TO30 and it came off a Ford 8N. Those two are the same length, axle to axle. However, I don't think the NAA is the same axle to axle as the 8N (or TO30). Are you sure your loader will fit on your NAA ok, even with a good front axle bracket? What model tractor did it come off of? Does yours bolt to the rear axle using the fender bolt holes like mine does? I am not close to my tractor with loader, but I can measure the front bracket next time I get there, if indeed you still need it. Email me if you like.
