4 gallons of hydr fluid in a 851?
Tom Smith
09-03-2002 18:02:51
I drained the fluid and found 4 gallons in my drain bucket. Dad must have gotten over zealous in his fluid levels. I put 2 gallons in like the manual calls for. He passed away in January and once again I find my self needing to ask him an important question. All too often dad knew things I never knew as may be the case now. Am I OK with this....looks good on the dip stick
nhpartsguy
09-06-2002 20:44:55
 Re: 4 gallons of hydr fluid in a 851? in reply to Tom Smith, 09-03-2002 18:02:51
Some manuals will state seperate capacities for the transmission and the rear axle. Four gallons sounds about right - an 8N holds nearly 5 gallons between the rear axle and the transmission.
CJ
09-03-2002 19:24:26
Did the tractor ever have a loader or other high volume cylinders connected to it? That could account for a need for additional fluid.
tom
09-05-2002 03:41:33
 Re: Re: 4 gallons of hydr fluid in a 851? in reply to CJ, 09-03-2002 19:24:26
Not that I ever remember. Can too much fluid hurt the thing? I would think not.
CJ
09-05-2002 20:20:12
 Re: Re: Re: 4 gallons of hydr fluid in a 851? in reply to tom, 09-05-2002 03:41:33
Tom, Too much oil can cause seals to leak. The correct level is the best.
