Sqeaky front axle pivot
Bill Seifert
09-08-2002 18:20:10
I have a near perfect original 53 Jubilee. It has developed a squeak in the pivot on front axle. It doesn't seem to have anyway to grease it that I can see. Doesn't look like a very smart patient to me. Do I have to disassemble the thing to grease it or am I missing something. Thanks Seif.
Tony Jacobs
09-09-2002 19:51:41
 Re: Sqeaky front axle pivot in reply to Bill Seifert, 09-08-2002 18:20:10
Hi Bill, I lost your Email address when my Netzero account finally went south completely, If you have tried to get in touch with me that's what has happened, drop me an Email so I can get in touch with you again. Thanks Tony JACOBS
Bill
09-08-2002 19:03:21
liberal doses of wd40..if you can jack it up,, you can move the axle back and forth.. make sure the pivot is not unscrewing and the pivot bushings (if equipped) are not moving..or wore out..
especially true on tractors that have had loaders on them, and the hyd pump shaft going through the pivot started to squeak due to worn out pivot and bushings..due to the weight.. i had to replace several pivots, and bolters (front casting) due to this problem with frontend loaders..
