Order Ford 800 Parts Online
1955 800 FORD
RICK KIPPLEY
09-10-2002 20:07:30
I NEED YOUR HELP OUT THERE 1ST I AM IN NEED OF A SET OF RUST FREE FENDERS FOR A 1955 800 FORD UTLITY ADJUSTABLE AXLES. I'M AT A DEAD END WITH NO WHERE TO TURN I'M IN WISCONSIN AND THAT DOESN'T HELP ANY ON THE RUST END. 2ND THIS TRACTOR IS 80% DONE AND IT SHOULD BE A PERFECT 10 AMYBE 9 1/2 I'VE GONE COMPLETELY THOUGH THE ENGINE & IT RUNS GREAT (BUT) THE ONE THING THAT DOESN'T SEEM RIGHT IS IF I LEAVE IT SET ANY LENGTH OF TIME IT SEEMS LIKE THE OIL FILTER DRAIN BACK INTO THE CRANK CASE SO WHEN I RESTART IT IT TAKES A WHILE TO GET OIL PRESURE, ONCE A GET PRESURE IT WHOLES GREAT???? ANY HELP OUT THERE ON EITHER WOULD BE GREAT.
tlak
09-11-2002 03:49:54
 Re: 1955 800 FORD in reply to RICK KIPPLEY , 09-10-2002 20:07:30
If your using a spin on they have an antibleedback valve and you might just need to change to a better filter.
RICK
09-11-2002 05:36:08
 Re: Re: 1955 800 FORD in reply to tlak, 09-11-2002 03:49:54
NO THIS IS THE CANISTER TYPE. BUT THOUGH THAT I MIGHT HAVE MISSED SOMETHING LIKE THAT IN THE BLOCK. THIS ENGINE DID THIS BEFORE WE OVERHAULED IT BUT I JUST FIGURED IT WAS WORN OUT
