Order Ford 4000 Parts Online
4000 series steering sector/box?
Mitchell
09-11-2002 15:11:43
I am trying to help out a friend with an early model 4000 forf with steering gear wear-does he need steering sector parts? Any help would be helpful
Grant
09-11-2002 21:24:38
 Re: 4000 series steering sector/box? in reply to Mitchell, 09-11-2002 15:11:43
Could be any number of things I just rebuilt my 4000 steering box I had a bent and twisted sector shaft and wore out needle bearings on the steering wheel shaft. The top needle bearing was pitted and dry (lack of lube) I still need all new ball joints, spindle bushings and power steering pump is bad. I&T manuel gives good breakdown of gearbox. I have a few pictures of mine during the teardown. Also have Ford part numbers for seals bearings and bushings.
Grant
geok
09-11-2002 20:31:20
If you can't take up the slack with the adjusting screws on opposite side of the gear box, he might.
There are also bushings that can be replaced that the sector shafts goes through.
