Order Ford 2000 Parts Online
2000 RUNs great for 10min then dies
dale
09-12-2002 20:19:54
my 2000 starts and runs great for about 10 min then just dies. i have changed fuelpump rebuilt carb. newtuneup.replace coil /????? ??
Will Sick
09-13-2002 17:18:02
 Re: 2000 RUNs great for 10min then dies in reply to dale , 09-12-2002 20:19:54
You either hav fuel blockage or the coil shorts out after it warms up. Take the gas line off at the carb and check the fuel flow. Its also possible that the float in the carb ishanging up or set wrong. My guess is fuel blockage. Th fuel flow is not quite keeping up with the amount needed.
Ken
09-12-2002 22:11:59
Dale, does your tractor have a rubber fuel line? Check to see if it may have a weak spot where the line could be collapsing shutting off the fuel supply.Does it start back up after dieing?
Eugene Branyon
09-13-2002 19:09:20
 Re: Re: 2000 RUNs great for 10min then dies in reply to Ken, 09-12-2002 22:11:59
If it has a rubber line replace it this will you problems at so point
rod
09-12-2002 21:48:21
More details. What year? Gas/Diesel? etc
don nc
09-13-2002 04:48:16
 Re: Re: 2000 RUNs great for 10min then dies in reply to rod, 09-12-2002 21:48:21
Is your fuel cap vented??
