Order Ford 4000 Parts Online
1962 Ford 4000 4 cyl gas fuel parts
Mike Wigant
09-17-2002 17:15:22
I've got a fuel leak from the piece holding the sediment bowl. Three different times I've ordered the part and the hole for the hollow bolt to pass through is too small. Also the fuel line coupling is too small. Can anyone tell me where I'm going wrong here?
murn
09-18-2002 15:46:32
 Re: 1962 Ford 4000 4 cyl gas fuel parts in reply to Mike Wigant, 09-17-2002 17:15:22
Mike,since I've been in Ford tractor parts for over 30 years,I have seen this mistake with new employes a few times.Up to ser no. so and so the bowl assy was 311272 after was CONN9155A or B. The bolt gskt prefix is a or b forgot which one for large bolt.hope this helps.
Rod MI
09-17-2002 22:51:51
I think you got the part for the 3 cyl and you need it for the 4 cyl. There are 2 gaskets that go on each end of the hollow bolt. Where is it leaking at? The fuel line connection or where the clear bowel attaches to the casting or at the hollow bolt. There are gaskets for each part did you by the hole assembly new and its still leaking is that the problem? Rod MI
Mike Wigant
09-18-2002 15:36:46
 Re: Re: 1962 Ford 4000 4 cyl gas fuel parts in reply to Rod MI, 09-17-2002 22:51:51
It's the old part that leaks, it looks like the casting warped. I may try to grind it a little truer or maybe a wad silicone would make do until I can find the right new part.
Rpd MI
09-18-2002 22:36:08
 Re: Re: Re: 1962 Ford 4000 4 cyl gas fuel parts in reply to Mike Wigant, 09-18-2002 15:36:46
you mite wont to try 2 gaskets on the leaking side I had the same problem and I tried gasket maker and it didn’t work I ended up buying new gaskets but they where much thinner I think I used 2 on each side but not shire Rod MI
Scott
09-17-2002 17:21:41
Where did you try? Go to an old New Holland (Ford) dealer.
