Order Ford 861 Parts Online
1958 Ford 861 Oil Filter
Tom Levi
09-18-2002 10:55:43
I just brought home a 1958 861 and want to change out the fluids and do a tune-up...I was able to find most of the info I need except where I can get the oil filter cart. and gaskets...Any one have any sources?...Thanks...
terry
09-18-2002 19:53:16
 Re: 1958 Ford 861 Oil Filter in reply to Tom Levi, 09-18-2002 10:55:43
For my 1964, 2000, I have been useing the standard ole ford filter that our pickups use cant remember the # right now, I dont know what the diferances are but so far I havent seen a problem with it.
Tom Levi
09-18-2002 17:38:49
Yep...I have the cartridge type...My goal is to restore this gal to her original condition...I think I'll go ahead and get the adpator to make routine maintenance easy as I plan to make her earn her keep but keep the canister available to swap when folks come by to admire what a great job I have (will) done (do) on the old gal...I'm sure I'll have additional question soon as I start this project...Thanks to all...
Jim.UT
09-18-2002 11:32:52
Any New Holland dealer can get it for you. I bought my last one at the local auto parts store that carries Wix filters. Can't remember the part number of the filter, sorry.
Tom Levi
09-18-2002 14:38:03
 Re: Re: 1958 Ford 861 Oil Filter in reply to Jim.UT, 09-18-2002 11:32:52
Thanks for the lead...I sent an inquiry on the Wix Website and got the follwing reply:
Wix part number 51004 should be used in your application. We have cataloging going back to 1943 to meet our customers' needs for older applications.
Thank you for your inquiry.
Chris Greeson
Senior Technical Services Manager
David Donaldson
09-18-2002 15:37:07
 Re: Re: Re: 1958 Ford 861 Oil Filter in reply to Tom Levi, 09-18-2002 14:38:03
I have a '57 861, the filtres are available at your NH dealer. There are two types of filtres for this tractor, the element (what I have) and the 'spin on' canister type. The spin on type requires an adapter. If there is a hex bolt head sticking out the centre of the filtre, then you have the elment type. Apperently the spin on adapter is only about $20.
The Element type filtre is messy to change.
