Pto pops out
bob
09-22-2002 12:26:36
what could be the cause of my pto lever sometimes kicking out seems to happen more when in reverse, is there a easy fix thanks i have to remove the top cover for the follower pin anyway any help would be thankful
Bill
09-24-2002 05:43:14
 Re: pto pops out in reply to bob, 09-22-2002 12:26:36
two reasons,, one is due the the detent-ball-spring being worn out,,and play in the shaft will allow movement forwards and reverse to allow the engagement collar to be pushed off..
the other is common on 8 and 9n.. is that right at the shaft end their is a twist and when ever pressure is applied, the shaft twist will actually force the collar gear forward.. Bill
