2120 Ford-New Holland 4wd
James
09-23-2002 05:44:07
Any feedback on the 2120? Is it a good reliable trctor? How about the trans and those with the HSS,how do thye stand up, what are the problem areas? Your insight is appreciated
James M
Scott
09-23-2002 09:45:01
 Re: 2120 Ford-New Holland 4wd in reply to James, 09-23-2002 05:44:07
It is a good loader tractor if you have counter weight on the back, for mowing it is not nice because when you push in the clutch pedal the pto stops, to get live pto you must start and stop the wheels with the forward/reverse lever which takes alot of getting used to and can't be done in close quarters.
