Ford oil spec.
Brad
09-23-2002 16:57:07
The sticker on the hydraulic oil tank on my Ford 340 skid loader says to use Ford M-2C48A motor oil. Can I assume that universal hydraulic oil is OK to use or does it call for a heavier motor oil.
In other words does anyone know the correct oil to use?
Bill
09-23-2002 17:46:32
 Re: Ford oil spec. in reply to Brad, 09-23-2002 16:57:07
m2c134d superceeds the previous including the m2c48b series oils... and yes, most of the Tractor rated hydraulic oils meet this rating. SAMs carrys tractor hydraulic in 5 gals for about $16.. do not buy the plain "hydralic fluid" as it has no anti rust or seal additives needed for your system.. so it must be rated "TRACTOR" hydraulic fluid from many vendors.. you will see the equivlent to M2C134-X on the back... Bill
