Order Ford 4500 Parts Online
4500 industrial front axle
dave
09-23-2002 17:37:05
Any one know how to remove the center axle pins. These are the pins that hold the axle to the tractor. The pins are tapered and press into the axle not the front end. The rear one is threaded and does not go all the way through it and the front one has a hole all the way through it. No place to put a puller of any type. Please help!!!!
ray
10-03-2002 03:06:57
 Re: 4500 industrial front axle in reply to dave, 09-23-2002 17:37:05
There should be a hex head bolt on the front pin. Back it out about 1/2" and drive it toward the back until the rear pin is loose. Then, drive the rear pin forward until the front pin is loose.
