Order Ford 601 Parts Online
601 hydraulics
AC Sam
10-02-2002 09:31:20
What would make the three point drop all at once when you barely move the lever. Also when it's down and you want to raise, as you start to move the lever nothing happens, then it comes up all at once. Any help or thoughts appreciated. Thank you.
Terry
10-02-2002 10:23:53
 Re: 601 hydraulics in reply to AC Sam, 10-02-2002 09:31:20
there is a lever under the right hand side of the seat, if it is float that is the way it acts. put the lever in the other position, and that should make it work the way you want.
