Order Ford 4000 Parts Online
1963 ford 4000 4 cyl diesel
Glen
10-03-2002 16:50:41
I would like to know what the proper fan is for this tractor 4 or 6 blade push or pull next where do the temperature and oil gauge connect on the block none existed when I got the tractor and I am a green horn thanks Glen
Scott
10-03-2002 18:03:41
 Re: 1963 ford 4000 4 cyl diesel in reply to Glen, 10-03-2002 16:50:41
The diesel uses a 2 blade fan and there are 2 different mounts depending if the water pump was replaced since 1971 or not, the later one uses a spacer between the pump and fan and the early one fastened right to the pump. The oil line connects behind the hydraulic pump and the temp. line connects on the right rear side of the head in front of the battery box,
