12 volt 641
AJ
02-10-2001 19:37:49
Just picked up a 641 with the 134 cid gasoline engine at an auction.I just now noticed it has a 12 volt battery ( negative ground), 12 volt generator ( not an alternator) but the coil is marked "6 volt. All cables are the size for a 12 volt system.At idle, the wire to the coil shows 12.8 volt. I think this is not good for the coil. Should I put in a 12 volt coil, a coil with a built in resistor, or a voltage reducer? If I put on a 12 volt coil will the points and capacitor "live"? Thanks, AJ
Texadian
02-10-2001 20:54:20
 Re: 12 volt 641 in reply to AJ, 02-10-2001 19:37:49
AJ, You're right, a 6 volt coil will not live long on a 12 volt system. My suggestion: wire it like the 12V 2000 to 5000 gas tractors 1965/. Use a resistance wire from the key switch to the coil (or an external resistor) to drop the voltage to approximately 6 or 7 volts) Run a second wire from the starter solenoid to the coil (no resistor) to feed the coil battery voltage while cranking for better starting.
AJ
02-11-2001 03:44:10
 Re: Re: 12 volt 641 in reply to Texadian, 02-10-2001 20:54:20
Texadian,
Thanks for the reply. Was this set up common for the gasoline engine? The tractor has a fuel gage but no ammeter. It does have a generator light. Since I just picked it up yesterday, I'm not sure about most of it yet. The head lights have been disconnected and has no switch. The original has been replaced with a starter switch. How can I determine the required voltage for the lights? I'm sure this great board will hear from me again once I start to work on this one. Thanks AJ
walt
02-11-2001 06:39:45
 Re: Re: Re: 12 volt 641 in reply to AJ, 02-11-2001 03:44:10
I have a 63 2000, converted when I got it. Lights disconnected. They were the original 6volt. Took one down to local auto parts store, found a match(12volt). Ran a hot off ignition switch to a light switch. Then hot to one side of light, and grounded the other side. I had a 6volt coil too, but I converted to electronic ignition, put in a 12 volt coil with built in resister.
