Order Ford 5000 Parts Online
10 speed selectospeed 5000
kenny
10-07-2002 07:37:44
I am having a problem with transmission fliud coming out the vent when the unit is cold in the reverse gears and the1-4 gears and the road speeds of 9&10. Sometimes when it sets up for long periods it will do it for a while in all gears. I thought some of you might have come across this problem before and could offer some advice. THANKS KENNY.
Larry NCKS
10-08-2002 18:28:03
 Re: 10 speed selectospeed 5000 in reply to kenny , 10-07-2002 07:37:44
Number one: check your fluid levels. Is it at the level it is suppose to be or is it overfull?
Number two: Have you recently had work done on this transmission where something (baffle) might have been left out? Your fluid level has to be too high or one of your components is throwing fluid against the breather when it rotates.
