1968 Ford 3550 TLB
Joe
10-18-2002 05:25:59
Tractor has 4 spd transmission but only 1
forward gear works. When I put the transmission
in a different gear and engage the hydrostatict lever, it acts like it wants to move but cant. I think the gear its in is 3rd or 4th since it wouldnt go up the truck ramp without a running start. Any thoughts would be appreciated.
Thanks
Texadian
10-19-2002 21:20:44
 Re: 1968 Ford 3550 TLB in reply to Joe, 10-18-2002 05:25:59
Most 3550's wer made with a four speed, power reversing torque converter transmission. You refer to the hydrostatic lever but I think you must mean the forward/reverse shuttle lever.
My guess is that there's not enough hydraulic pressure to lock up the forward or reverse clutch packs. Maybe a leak, worn transmission pump, low fluid, plugged filter, failed transmission pressure regulating valve. Needs a pressure test.
Also possible is a worn out torque converter.
