3PH lift arm pin size?
Fighting suburb
10-21-2002 04:30:37
I looked in the manual but nowhere does it give the size of the pin that holds the vertical lift arm to the lower arms. Without cutting the "left-handed engineered" junk on mine off first I cannot measure the diameter of the holes the pins slide through. What size and what material do these need to be? Anybody have a good source for these pins? Since they see some pretty good shear and shock loads I figure a hardened pin is better.
If nothing else I will use a shoulder bolt of the correct size and put a nylock nut on it then cut off the excess length.
forworkma
10-21-2002 07:14:37
 Re: 3PH lift arm pin size? in reply to Fighting suburbia in NC, 10-21-2002 04:30:37
I just bought a pair of these shoulder bolts from my NH dealer. Kinda pricey @ $16 each.
