172, any other engine that will bolt in?
Adam Whitson
02-12-2001 08:32:36
I am in desperate times here. I cant find a rebuildable 172. Does anyone know what other engine will bolt to the bell houseing? I can make the other modifcations, but I must use the existing bell houseing.
ABW
Cj
02-13-2001 20:59:58
 Re: 172, any other engine that will bolt in? in reply to Adam Whitson, 02-12-2001 08:32:36
What is the engine in that also came with a chrysler slant 6? Definitely not a Ford tractor! Sounds like it froze good and solid. My condolences but it makes antifreeze look cheap now doesn't it!!
Adam Whitson
02-13-2001 21:01:52
 Re: Re: 172, any other engine that will bolt in? in reply to Cj, 02-13-2001 20:59:58
This is an oliver swather. Yes antifreeze is cheap, perhaps I can forward that gem to the previous owner.
adam whitson
02-13-2001 16:52:52
Im in central kansas.
I am not limited to a ford 4 cy. I know that the chrysler slant 6 also came in this machine (with a different bell housing). So i was looking for all engines, not just fords.
John-COLO
02-13-2001 04:36:07
I have the parts or a complete running engine in Denver. 134 or 172.
Tony Jacobs
02-12-2001 23:04:45
Hi Adam, As Al said a 134 engine will fit , the Diesel will also as will the 192 Industrial engine . Where are you located ? I live in Mass ? I have Blocks available and maybe a head , those are getting tough to find though . Thanks Tony Jacobs
charles Seideman
02-12-2001 19:45:39
I have a 172 block. For $200 pluis shiping you can have it. I am in Austin TX
MarkB
02-12-2001 18:52:27
Just out of curiosity, what's wrong with the 172 that you have? Short of a busted block, I can't imagine too many things that could render it totally non-rebuildable. Sure, it will cost mucho dinero to do a major rebuild, but swapping engines could turn out to be more expensive in the long run.
adam whitson
02-12-2001 18:57:29
 Re: Re: 172, any other engine that will bolt in? in reply to MarkB, 02-12-2001 18:52:27
cracked head, cracked block, new pistons
abw
Al English
02-12-2001 08:54:05
Hi Adam, I know a 134 gas will work, and I think a diesel of the same vintage will fit in tractor without major changes. Tony Jacobs is really up on this, hopefully he'll see this and give you more details...Al English
