1710
Dan
10-23-2002 17:09:52
Ran the 1710 out of fuel. Filled and it started immediately but sounds now like it is running on 2 cylinders instead of 3. Is there a bleed screw on the injector pump or do I have to bleed each injector individualy? Thanks and why isn't there a fuel gauge on these things?????
TomG
10-24-2002 04:18:24
 Re: 1710 in reply to Dan, 10-23-2002 17:09:52
My 1710 has a fuel gauge but I think there were some production changes around '85.
It sounds like there is air in the lines. If it hasn't gotten to the injector lines it can be bled out by opening two bled screws on top of the fuel filter and opening the shut-off valve untill air stops bubbling out. Then the pump is bled.
The bled screw for the pump is located on the front. It is sizable and has a hex head with a slot screw head in the centre. It screws out quite a ways before fuel and bubbles start coming out.
I'd be generous with the amount of fuel allowed to come out of the bled screws because 1710 pumps are particular about air. I used to bled mine 3 or 4 times before it was OK. Now I just let more fuel flow.
If it ran out of fuel there's a good chance that there is air in the injector lines and bleeding the pump won't clear it. If you're not familiar with safety precautions for bleeding injector lines, a manual procedure should be followed.
There is a 10mm bolt on top of the pump. That's for adding 100cc of clean engine oil at every oil change. It just ensures the pump has clean oil.
Dan
10-24-2002 10:50:45
 Re: Re: 1710 in reply to TomG, 10-24-2002 04:18:24
Thanks. It seems to have bled itself overnight. Started and ran this morning just fine. I appreciate the response though.
