Order Ford 860 Parts Online
860 propane now gas
Bill Price
10-25-2002 20:11:51
If my tractor, model 860-L, serial number 1361185, was made to use propane and now uses gasoline, does that mean the motor was changed? Or can a propane engine be converted to run with gasoline? I'm wondering if I have a different motor or if the 5 at the end of my serial number means a dealer converted my tractor over to run on gasoline> Any thoughts on this would be appreciated.
Bill
Jim.UT
10-26-2002 10:12:12
 Re: 860 propane now gas in reply to Bill Price, 10-25-2002 20:11:51
Another likely scenario is that your tractor was always a gasoline tractor and had it's transmission replaced with one salvaged out of a propane tractor since the model and serial numbers are stamped on the transmission. Does your tractor have the big propane tank sticking out of the hood?
Larry NCKS
10-26-2002 04:59:57
Your engine was likely converted from propane to gasoline. That's no big deal, but converting a gasoline engine to propane would be hard on valves.
