Order Ford 861 Parts Online
1960 model 861 points/resistor problem-12 volt
Don Olson (Mi)
10-31-2002 18:58:58
Hello, I purchased a 1960 model 861 ford powermaster 4 cyl gas tractor that had been converted to 12 volt system. Problem is points burn up. The resistor to distributor voltage reading is 12-13 volts, should the resistor not reduce the voltage to 6 volts? The tractor has a gm alternator and a ford 12 volt coil. Thanks for your help. I replaced the resistor but voltage is still 12-13 volts. Don (Mi)
MarkB
11-01-2002 03:28:44
 Re: 1960 model 861 points/resistor problem-12 volt in reply to Don Olson (Mi), 10-31-2002 18:58:58
With the distributor points CLOSED, read the voltage between the positive and negative coil terminals. It should be around 6 to 8 volts. If this voltage is 12 to 13 volts, then the resistor isn't installed correctly. If it's zero, your points are open.
al
10-31-2002 20:22:47
Where is the resistor in the wiring,it should be before the coil.
