19-202 Loader?
Tom
11-05-2002 15:14:51
Can someone fill me in on a Ford 19-202 loader? I am restoring one and it is off the tractor, but I would like to know a little more about it. When were they prodced ? Does it have a floating blade option so it will not dig in but float on the ground when I plow or do other FEL work? It wuld be good to know if there area ny features it has that I could put to work for me. thank you. tom
Does it look like this?
11-06-2002 19:39:26
 Re: 19-202 Loader? in reply to Tom, 11-05-2002 15:14:51
third party image
If so, this is a 702 loader, or so I'm told. What do you have it mounted on?
kevin
My earlier posting about this thing
11-06-2002 19:44:02
 Re: Re: 19-202 Loader? in reply to Does it look like this?, 11-06-2002 19:39:26
Posted by kevin on November 01, 2002 at 17:26:03 from (68.13.157.214):
Snowy greetings:
I am having a heck of a time finding a info on part 19-202. Is this indeed the 702 loader? I can find every number BUT this on the New Holland search. Is this similar to a 703? Specifically, I am looking for the front mount bracket for an 8N, and I know for a fact they made them as I have seen it listed in the dealers parts book. You just can't get them anymore. I will make a bracket if'n I can get the dimensions. Since mine is serial# 1471, I know there is another somewhere.
thanks for reading
kevin
Royce H
11-06-2002 07:34:08
Ford made a Model 19-209 1 arm loader for use on 800-801 series tractors.One bracket mounted directly under the front of the engine in factory tapped holes. The other bracket mounted on left side of tractor in factory tapped holes. Manuals are still available from Ford/NH. I bought one last spring. CAUTION!! These loaders were made for very light use such as cleaning out barns. DO NOT attempt to load Large hay bales or use it to pick up heavy objects.
Mine is a regular two arm
11-06-2002 07:59:24
 Re: Re: 19-202 Loader? in reply to Royce H, 11-06-2002 07:34:08
The number of my FEL is 19-202. Interesting that the one arm is 19-209. didn't know that.
