4cyl 314C specs needed
Scott
11-08-2002 09:37:19
Most 314C Tractors were made with 3 cyl engines but the tractor I have was made for the Army and came with a 4 cyl engine. I have not been able to get the timing specs or the valve adjustment specs. If any one can help with this I will list other info below that might help. 1984? Ford 314C, s/n C697212 ,4 cyl Diesel , Eng# D5NN6015 (T3), Trans #C5NN-7222-R , 4 speed over/under ,Rear Housing Case #EONN4024HA . Thanks
Texadian
11-08-2002 10:28:44
 Re: 4cyl 314C specs needed in reply to Scott, 11-08-2002 09:37:19
Same power train as model 6610. Use 6610 specs for timing, valve lash.....
