Oil bath cleaner on 600
ATTEN: DON M
Alabama
11-09-2002 12:21:25
Don and everyone else. Thanks for your input on previous post 10/28. My problem is oil bath cleaner not lining up with sheet metal opening. Looks like 2 mounting holes on each side in steering gear assembly. Mine was mounted to upper hole. This could account for oil bath filter not lining up. I have sheet metal off. Question. Does anyone know which hole is correct one to use for '65 model 600? And why there are two? Also if I drop down to lower hole, do I have to lower front end sheet metal also to keep proper alignment? Right now, dash sheet metal is about 1/2" below hub on steering wheel. If I lower it to bottom hole, then dash will be about 2" below steering wheel hub. Does this seem correct? Thanks in advance. David (Alabama)
Scott
11-09-2002 18:16:57
 Re: Oil bath cleaner on 600 - ATTEN: DON M in reply to Alabama, 11-09-2002 12:21:25
The top holes are for the 800 because they had larger gas tanks.
Alabama
11-10-2002 10:21:48
 Re: Re: Oil bath cleaner on 600 - ATTEN: DON M in reply to Scott, 11-09-2002 18:16:57
Scott, thanks for the reply. So that means that the steering gear assembly and front end parts were used on the 800 and 600 series? Thanks
