Charging system
Ben
11-14-2002 06:02:36
I have a 800 ford tractor with 6 volt system. Problem is that ammeter flickers from full charge to discharge. I had the Gen checked and also installed a new regulator (Pos Grd). At normal operating speed the needle just flys from charge to discharge. Any Ideas. Battry is now dischaged and on a charger. Appreciate any advise. Thanks Ben
DavidO
11-14-2002 10:46:51
 Re: Charging system in reply to Ben, 11-14-2002 06:02:36
After you reinstalled the generator and installed a new regulator, did you polarize the generator?
What is the voltage reading across the battery terminals with the tractor running?
