Order Ford 640 Parts Online
1954 Ford 640 Hydraulics Continued
Larry Hardesty
11-14-2002 18:38:04
After not being able to get to my tractor for a few weeks, I started it today. I have had the problem of the lift going up and sticking there. I had the bush hog on it and ran it for awhile. Eventually the lift when down and would not come up--or do anything when I moved the lever. Don't know if this gives further clues as to what might be wrong. I ordered the o-rings and gaskets to open it up. Further advice welcome. Thanks in advance
Phil (VA)
11-15-2002 07:46:41
 Re: 1954 Ford 640 Hydraulics Continued in reply to Larry Hardesty, 11-14-2002 18:38:04
When you get it open, look at the cam follower pin. Even slight wear will cause a problem similar to yours. Zane has the pins and instructions on replacing them. You probably can get them from a NH dealer also. They are in a non lubricated spot so they wear easily. It often takes two people to remove the pin as you need backing to drift it out, or as Zane says, one to pound on it and one to cuss.
Al
11-14-2002 18:49:48
I have seen linkages rust under the cover if the tractor sits a lot these could be sticking.
BOB
11-15-2002 04:08:10
 Re: Re: 1954 Ford 640 Hydraulics Continued in reply to Al, 11-14-2002 18:49:48
what type fluid do you have in it?
Larry Hardesty
11-15-2002 11:26:30
 Re: Re: Re: 1954 Ford 640 Hydraulics Continued in reply to BOB, 11-15-2002 04:08:10
The current fluid is what came in the tractor when I got it about a month ago. Looks little brown like water in it. I got some replacement fluid from the local TSC store. Perhaps this weekend I will have time to replace it. Do you think that alone will cause the problems I have been having?? Thanks
Larry
Phil (VA)
11-15-2002 13:42:52
 Re: Re: Re: Re: 1954 Ford 640 Hydraulics Continued in reply to Larry Hardesty, 11-15-2002 11:26:30
I doubt it. See my post above for another possibility.
Larry Hardesty
11-15-2002 14:04:56
 Re: Re: Re: Re: Re: 1954 Ford 640 Hydraulics Continued in reply to Phil (VA), 11-15-2002 13:42:52
Got it and e-mailed Zane for the availability of the piece. If not, I will try the local (30 miles away) NH dealer...don't know if I should get the piece anyway and replace it when I have the hydraulics open or wait and see how bad it is. Thanks
Larry
Jim Spencer S.E. Michigan
11-16-2002 14:56:12
 Re: Re: Re: Re: Re: Re: 1954 Ford 640 Hydraulics Continued in reply to Larry Hardesty, 11-15-2002 14:04:56
Larry:
The pin is only about $1 so you should have it on hand if you get where you can buy it.
Then pin rides on a cam (no lube)and wears out.
Jim
