Order Ford 3000 Parts Online
1970 3 cyl. gas 3000 surge problem
David (Ala)
11-17-2002 19:12:16
Pete and Bill. Thanks for the replys. My surge problem will not go away no matter how the choke is set. In or out or in between. I'm thinking clogged fuel line or filter somewhere. Any ideas?
bill
11-19-2002 10:15:23
 Re: 1970 3 cyl. gas 3000 surge problem in reply to David (Ala), 11-17-2002 19:12:16
disconnect the fuel line from the carb and crank it over with the fuel line pointed away from the tractor.. see if your fuel pump is working.. if it will fill a coke bottle in less than minute of cranking(or even half), its fine. you probably have a stopped up carburator main jet and need to disasymble, clean, blow out and reassymble.. good luck Bill
David Grigsby
11-19-2002 20:47:56
 Re: Re: 1970 3 cyl. gas 3000 surge problem in reply to bill, 11-19-2002 10:15:23
Thanks Bill.
