3 fill ports three questions
Eddy(OR)
11-21-2002 00:55:36
I got an old 800 recently and i don't know a lot about them. I want to drain the fluids and replace them.
1. At the rear is a fill hole for fluids. What kind how much, and what weight or type of fluid goes in there?
2. At the hydraulic lift is another fill port what type, how much, of fluid goes in there?
3. on the transmission shift cover is another port. What kind, how much of fluid goes in there?
Eddy
Ben E.
11-21-2002 06:20:42
 Re: 3 fill ports three questions in reply to Eddy(OR), 11-21-2002 00:55:36
Differential Capacity: Row crop model only, 8 quarts - All other models 11 1/2 quarts (80-90W gear oil)
Transmission Capacity: Four speed 6 1/2 quarts, Five speed 8 quarts (80-90W gear oil)
Hydraulic oil Capacity: On models without both hydraulic system and PTO, leave hydraulic reservoir empty. On models without hydraulic system, but equiped with PTO, add 6 quarts. On models equiped with hydraulic system and PTO, add 8 quarts (134 hydraulic oil) available at your nearest "FRIENDLY" Ford New Holland dealer.
Have fun with your old 800 & good luck.
Ben E.
