Order Ford 4400 Parts Online
4400 5' or 6' brush hog?
Gary
11-22-2002 17:18:32
What are the opinions pro and con, of buying a 5 foot or a 6 foot brush hog to use on a 4400 tractor. Any problems getting into tighter spots with a 6 footer? More maintenance problems?
Thanks
Gary
AJ in VA
11-22-2002 19:54:51
 Re: 4400 5' or 6' brush hog? in reply to Gary, 11-22-2002 17:18:32
Get the six footer, because you will be cutting over your tire tracks in one pass. What I mean is that the six footer is as wide as your tractor over all and you won't have to run over the same grass twice to cut your area once where the tire have been. Does this make things clear? Also, if you can get the tractor through a place you can get the six footer there to. Your tractor is six foot wide get a tape measure and check you'll see. Remember in six rounds that is one round more in ground area you will have covered then with a five footer.
