Order Ford 3000 Parts Online
3000 Comp Test
David (Ala)
11-24-2002 19:35:53
I am going to do a comp test on my 3000 gas. Test with all plugs out? How long do you turn it over before you take a reading? The longer you crank it the higher the compression reading? I have the I&T manual showing the range and desired reading.
Thanks, David
Dan J
11-26-2002 05:10:36
 Re: 3000 Comp Test in reply to David (Ala), 11-24-2002 19:35:53
David, Take all the plugs out and test one cylinder at a time that way. It should reach maximum compression in 3 or 4 turns but count them and do each cylinder the same way. Good luck, Dan
David (Ala)
11-26-2002 20:21:43
 Re: Re: 3000 Comp Test in reply to Dan J, 11-26-2002 05:10:36
Thanks Dan
