4110 engine problem
Horseman
11-25-2002 04:44:45
So I was useing my friends 4110 ford loader and it just started sputtering when I tried to rev it up with the foot feed. It also lost alot of power. It sounds almost like its poping through the air cleaner. First thing I thought, was a valve of some sort. But I tried cracking each of the injector lines to isolate wich cylinder but they all seemed to affect the engine the same. I'm no diesel tech so any Ideas Ya'll have would be great. Thanks WRP p.s. I pulled the valve cover and every thing is working as should there.
fredo
11-25-2002 22:12:15
 Re: 4110 engine problem in reply to Horseman, 11-25-2002 04:44:45
had the same problem on [7500] tbl. put some ijector leaner in fuel it sure runs a lot better now. didn't help to change filter.
RickB.
11-25-2002 14:20:46
Change the fuel filter, bleed the system properly. Be sure there is a good flow of fuel from the tank to the filter head while you are at it. If there is not a good flow of fuel to the filter head, find out why and correct the supply problem. If you have to post back, tell us whether it is a 3 or 4 cylinder, 'cause that model # can be found in both versions, and they are completly different tractors.
Horseman
11-26-2002 05:57:33
 Re: Re: 4110 engine problem in reply to RickB., 11-25-2002 14:20:46
it is a 3 cyl and i removed the filter and it was full of gunk. I'll update you as soon as i can thanks WRP
