Cold weather and air cleaner oil
Bill
12-03-2002 14:01:01
Hey my new 12V system and ring and valve job fired the old girl with a slight push of the button. but now that it's cold it is cranking a few more times before it starts with a large puff of black smoke.
Is it harder to start these 172 engines with the air going through cold and thick air filter oil in the oil cup? and causing it to start harder?
And is the black smoke on start up just fromsome minor flooding when it is crnaking a few times before it catches? it's a relatively new rebuild last fall with new rings sleeves and pistons, new battery, and fluids.
RickB.
12-03-2002 16:35:57
 Re: Cold weather and air cleaner oil in reply to Bill, 12-03-2002 14:01:01
Gas doesn't atomize as well in winter as it does in warmer weather. The smoke may be unburnt fuel. Use the same oil in the aircleaner as you use (or are supposed to use) in the engine for a given temp range.
