Order Ford 4610 Parts Online
4610 Ford
David
12-10-2002 09:55:40
I need to replace the clutch on my tractor. I wanted to make this a 1 weekend project. Go and buy the clutch, pressure plate and bearings, replace and then return the used parts for the core charge. The parts man said he will have to see the old clutch and pressure plate first so he can make sure I get the right one. Seems there are 2 possibilites. Is there any we to be sure which setup I have so I don't have a 2 weekend project?
Bern
12-10-2002 18:40:41
 Re: 4610 Ford in reply to David, 12-10-2002 09:55:40
Seems to me like the two possibilities are 11" and 13". I'd pull the starter out and look through the hole with a flashlight and mirror. The 13" will take up most of the flywheel. The 11" will be noticeably smaller.
I do believe also that the 11" will have four separate throwout fingers, whereas the 13" will have the four fingers with a common "push plate" connecting them.
Alton
12-10-2002 15:07:33
If he can look it up by the serial number he should be able to tell which is in the tractor. If he can't then you may have to pull out and take it to him. Maybe try another source.
