Remote hydraulics operation
boomer
02-17-2001 11:33:40
I was wondering about the operation of a remote hydraulic set up. If you use this does it still allow you to use your 3pt hitch? I have a loader and I was using the port on the accessory plate.When this port is used, the 3pt hitch needs to be locked up rendering it inpoerative. I just want to make sure if I put the remote on, it doesn't render the 3pt inoperative
Any comments will be greatly appreciative
Matt
Greg NE
02-17-2001 18:02:08
 Re: remote hydraulics operation in reply to boomer, 02-17-2001 11:33:40
What kind of tractor do you have? I have a 63 4000 that I have a loader on and it is hooked to the single remote and it works fine. The only thing is when I am pushing snow and I have my 6ft blade on the back I can't raise the loader and the 3pt at the same time but that really doesn't bother none, just have to raise one first and it only takes a few seconds. Greg NE
