Order Ford 2000 Parts Online
Frozen Spark Plug on Ford 2000
Bob Healey
12-14-2002 13:44:31
I just bought a Ford 2000. It is a gas model 3 cylinder. Water has leaked into all 3 spark plugs and frozen them. There was much corosion, which I cleaned out. I was able to break 2 of the spark plugs loose, but the last one has refused to give up. Does any one have any idea how to get the spark plug loose without removing the head and bringing it to a machine shop. I have imersed the plug in WD-40 and other penetrating oils to no avail. Thanx a million.
bob
david
12-14-2002 16:03:05
 Re: Frozen Spark Plug on Ford 2000 in reply to Bob Healey, 12-14-2002 13:44:31
had a plug like that one time and ended up putting some heat with the torch on the metal base of the plug for just a minute till the base was red in one spot. Let cool and then she came right out.A little extreme but sometimes extreme measures are required.Good luck,David
buck
12-14-2002 14:19:47
use an impact wrench.
raytasch
12-14-2002 16:20:18
 Re: Re: Frozen Spark Plug on Ford 2000 in reply to buck, 12-14-2002 14:19:47
If you use an impact wrench do it on low power. Don't ask why. The vibration will help. ray
