Order Ford 661 Parts Online
1958 661 no key switch
Drake
12-14-2002 19:17:51
my 1958 ford 661 has no key switch just a push button start but the wiring diagram has a key switch does anyone know if it should have a key
Tommy D.
12-16-2002 09:26:12
 Re: 1958 661 no key switch in reply to Drake, 12-14-2002 19:17:51
Here's what I did.....When I got my '64 4000 4 cyl. gas, I saw a pull switch on the right side, just above where my right knee is when stiitng in the seat.....I ass-m-me'd that someone had "rigged" this to be the ignition switch..... My ole farmer neighbor was over looking at her, and I told him that - He is still laughing at me....There, just on the opposite side, above my left knee, low & behold, a key switch! It was ignorance on my part....hee hee
I would do as others suggest - trace backwards from the coil...
Good Luck!
Tommy D.
paul
12-16-2002 14:55:24
 Re: Re: 1958 661 no key switch in reply to Tommy D., 12-16-2002 09:26:12
So, did the lights come on the first time? :)
There has to be a switch, or how would they shut the tractor off?????
--->Paul
Tommy D
12-17-2002 10:13:21
 Re: Re: Re: 1958 661 no key switch in reply to paul, 12-16-2002 14:55:24
Actually, no, because the battery was gone.....Sure worked when I got another battery and got juice to them..... Been working ever since...
TD
Jim.UT
12-14-2002 21:05:53
Rick is right. The button on the transmission just spins the starter. The key switch sends power to the points. Won't run otherwise.
Often the key switch goes bad. A common repair over the years has been to replace the key switch with a toggle switch. Look for a toggle switch somewhere.
If someone wired the points to be hot all the time you'd eventually burn up the points or drain the battery. Gotta be a switch of some kind somewhere. Try following the wires backwards from the coil back to the switch. When I first got my tractor it had a toggle switch wired into the line, not mounted to anything, just wrapped with about 6 coats of electrical tape. It has a key switch now!
RICKWI
12-14-2002 20:16:47
Button just runs starter, switch turns on the juice. Gotta be there.
