9n141
12-19-2002 17:47:30
Prices in Canadian funds (US= aprox 66% of Canadian i.e. $1.00 CAN =$0.66 or $1.50 CAN=$1.00 US ), rings $155.,rod bearings $57, main bearings set $75, grind crank 20 th $135,gasket set etc $61 TOTAL to here $485. 2 valves $20,manifold $120, tune up kit $25, oil pump $178,muffler $26,coil $26,carb overhaul $52,dist cap $15, batt. $60, fluids & filter $100, misc $100 now we are up to $1200 grand total to here. Add from parts in stock Sherman O/U , engine crank, under slung drawbar, tool box , the complete tractor! The good news all other parts very good i.e. rad, hydr.,3pt, pto, gas tank,trans ,clutch, brakes, steering, sheet metal with script, tires& rims very,very good. Labour aprox. 50 hours. This has brought it up to a good reliable & usable tractor. No extra cleaning done or painting. I hope this helps others with their dec. It would be real helpful to me & others if the board members would put aprox. values on the tractor, the Sherman, & other parts used. Thank you BURT.
