Order Ford 640 Parts Online
1957 640 ford freeze plug question
JED
12-26-2002 12:02:02
Help! The rear left plug has developed a pin hole leak. Can this be fixed without pulling the engine apart? If so it would be a shame because I can get right to this area with no problems without moving a thing. I have seen after-market replacements for older cars that don't have to be installed from the inside out, so what about my tractor? I can't seem to find any plugs specific to my 640. Would I use an auto replacement the same size? or does anyone know where else I can look? Thanks to all ... what a great site!
JED
12-26-2002 17:47:54
 Re: 1957 640 ford freeze plug question in reply to JED, 12-26-2002 12:02:02
Thanks! To everyone here it looks like I have several ways to handle my problem. Thanks again. You guys are the best!
Sky
12-26-2002 17:42:57
Jed,if you live in cold country,you might also look into getting a freeze plug heater,I've seen them on e-bay for about 10-15 bucks.Fits in place of the usual plug.might also be a FNH part,you never know.
Sky
John
12-26-2002 16:36:08
I don't see a problem with replacing from the outside. Obviously drain the coolant, and make a clean extraction of the old one.
Sam MI
12-26-2002 14:45:27
Jed; The replacement plug you need is, (Dorman 555-048), 2.062 ouside diameter. Available at NAPA stores and other automotive stores. The New Holland number is 7HA6266A. HTH
